So i have ran a couple of tests with different kind of floors,walls,beams and columns. I have noticed that speckle can not properly copy some of them. The things i have tested are listed below with the results. In the end of this post the link to the stream will be provided.
Thanks so much for sharing the Revit file with us and helping us to improve Speckle. I was able to reproduce all of the described issues and made several fixes that you can see in the pull request here if you are interested. The only thing I didn’t fix is recreating one of the floor elements with it’s original subelements. That one is going to take a bit more work to implement.
I wasn’t able to get this fix done in time to make it in the 2.11 release today, so I have it targeted for 2.12. If you urgently need this functionality then I can ping you to help me test it a bit, and then I can make a hotfix for 2.11 instead.
Nice to hear from you again . I am happy to see these problems have been resolved so quickly. Hopefully you will be able to find a fix for the floor element mentioned. I will patiently wait for update 2.12.
Again thanks for reaching out and have a wonderful day! @jonathon Thanks to you as well.
