I built an NPM package to make the process of authenticating apps with Speckle easier. It handles the OAuth process and I tried it hard to make it as simple as possible. I’d appreciate if you could give it a spin and write me any feedback you have.
Here’s a link:
import { SpeckleAuthClient, type ApplicationOptions } from 'speckle-auth';
const options: ApplicationOptions = {
clientId: 'your-client-id',
clientSecret: 'your-client-secret',
serverUrl: 'https://app.speckle.systems',
const speckle = new SpeckleAuthClient(options);
async function authenticateUser() {
const user = await speckle.user();
if (!user) {
await speckle.login();
return user;
async function logoutUser() {
await speckle.logout();
@vwb thank you for publishing this handy package I’ve been having some trouble understanding to properly handle the login process.
When the redirect returns it seems to get stuck with trying to access the challenge code passed back in the url. I’ve been fiddling with the redirect endpoint and have gotten some mixed results, sometimes the auth process works as expected but then it will break without any change to the config or app. I have a haunch that this is more of a problem with how I should be handling the redirect, or maybe in how await client.login() should be handled within a react-app, but since my understanding of oauth is questionable at best, I figured I would seek help from the high council of specklers.
Here is an example setup using a test app. I also isolate the script and logs below since stackblitz seems to throw some errors with the post call.
@vwb appreciate the quick reply + example! I see what I was doing wrong, the client object needs be moved out of the app block.
One thing that should be changed is wrapping the first auth check in useCallback since an async method in useEffect will cause some issues when mounted. Without it I was getting POST .... /auth/token/ 401 on the redirect.
hello, i was implementing Speckle auth library, and i’m new to this, please guide me somewhere, this is the react code, i’m getting logged in successfully and then moved to my workspace, then i get pushed back to the login page and get’s logged out
