Speckle ArchiCAD is not finding ArchiCAD installation
Hi Everyone,
I’m having trouble installing the Speckle ArchiCAD Addon for my ArchiCAD 27 version.
The installation of the Speckle Manager went smoothly, and the addons for other software are working fine. However, when I try to install the ArchiCAD Addon, I encounter the following issue:
prob
Is there a way to manually set up the Speckle connection.apx? For that, I would need the plugin data. Is there any way to download it separately?
Thanks in advance for your help!
Hey @Monty_Lipphardt ,
As the warning indicates, you can manually install the addon by locating the .apx file in the path specified in the error message:
%appdata%/Speckle/Archicad/[VERSION]/Add-Ons/Speckle Connector.apx
Here’s a post that explains how to install it manually:
