Hello Speckle forum,
Today i ran into an issue with Revit rebar not getting transferred when using a Speckle stream.
As an example here is a basic concrete floor made in Revit. Nothing is changed from it except for the added rebar.
When i send the elements to Speckle i get the following message. This seems fine.
I create a new project and preload the used rebar shapes into the project. Then i press receive.
As you can see the floor element is created but the rebar is missing from it. Instead Speckle created a Geometry.Line representing the shape of the rebar.
Link of the stream: Stream | Speckle
Is it possible to get this working in Speckle?
With kind regards,
Rowan
