Speckle 2.12.2 - Generic model with void or solid face based family as cutout
Good afternoon,
Today i was testing to create a workflow using speckle. I have a main model and a shadow model. I use the shadow model to add rebar. This is for multiple reasons, not relevant to this problem.
In the main model i want to add cut outs to an element. This element is a Generic Model Adaptive (GMA). I made a Face based generic model (FC-GM) as a void(tried a solid in another workset as wel) and added it to the main model. I cut the geometry, send this information (both the GMA and the FC-GM) to Speckle.
Both the elements are send and i can see that one of them is attached as hosted element to…(see image)
in the preview window i can see the element.
After that I open the shadow model and add the same GMA and FM-GM before i press receive.
Only one element is received from Speckle the FC-GM is not created.
If i try to send the hosted FC-GM on its on it does get created by on a totally different location.
Can this issue be fixed? If you have any questions please contact me directly or comment on this post.
Hey @Rowan ,
I think it can be fixed. Can you share the sample file with us? You can send a DM if you don’t want to share it publicly. It’ll make debugging easier.
