Some Texts flipped upside down in the viewer
Hej!
I have a modell displaying values on vertical planes and noticedthat sometimes, the text object in Speckle randomly gets flipped upside down. Not sure what would be the cause of this since it doesnt seem to be consistent with plane orientation and all the text settings should be the same.
The whole modell including these text objects are sent from Rhino ( baked from grasshopper)
Pretty weird behaviour, Any ideas?
If you receive these again in GH/Rhino are they reverted correctly?
Yes, aparently! That seems to be the case: receiving the stream back to rhino has all the text displayed correctly
@Andrei I have logged to issue as a bug for engineering to review.
After further inspection, wanted to add that most the flipped texts are on planes that are aprox. perpendicular to the correct ones. Should help narrowing down this issue
