SketchUp data is not getting received in Revit with speckle connector
Hi Team
I create a stream and send SketchUp file on the same stream then open Revit and open the same stream to receive the 3D file data into Revit, but it is showing an error.
Please have a look at the below mentioned error
Unable to cast object of type ‘Objects.Geometry.Line’ to type ‘Objects.Geometry.Curve’.
at Objects.Converter.Revit.ConverterRevit.ModelCurveToNative(ICurve speckleLine)
at Speckle.ConnectorRevit.UI.ConnectorBindingsRevit.ConvertReceivedObjects(List`1 objects, ISpeckleConverter converter, StreamState state) in C:\Users\circleci\project\ConnectorRevit\ConnectorRevit\UI\ConnectorBindingsRevit.Receive.cs:line 195
Value cannot be null.
Parameter name: source
at System.Linq.Enumerable.Select[TSource,TResult](IEnumerable1 source, Func2 selector)
at Objects.Converter.Revit.ConverterRevit.BlockDefinitionToNative(BlockDefinition definition)
at Objects.Converter.Revit.ConverterRevit.BlockInstanceToNative(BlockInstance instance, Document familyDoc)
at System.Collections.Generic.List1.ForEach(Action1 action)
TessellatedShapeBuilder failed to build the requested geometry.
at Autodesk.Revit.DB.TessellatedShapeBuilder.Build()
at Objects.Converter.Revit.ConverterRevit.MeshToNative(Mesh mesh, TessellatedShapeBuilderTarget target, TessellatedShapeBuilderFallback fallback)
Line is slightly off axis and may cause inaccuracies.
Please have a look at the attached test mode file.Processing: TEST MODEL.skp…
Hey Kumar, yes we know and we’re working on this! Please see: 🚀 Speckle SketchUp Connector Alpha - #4 by izzylys for more info. And thanks for reporting!
Hey @Kumarravi007 :wave:,
We recently released a Mapper tool that allows you to convert your Sketchup models into Revit models. Take a look:
Feel free to share any feedback you have.
