Just trying to sign in from grasshopper! It probably need a quick fix.
Which connector version do you have installed Ashkan?
I just installed in from https://app.speckle.systems/connectors
they look crisp and nice so I don’t think it have any leftovers from old ones
a version number would still be appreciated - but I’ll assume 2026.9
yes it is “Version 2026.9.0”
signing into app.speckle.systems or your own server?
Our quickest fix for this is to login with Rhino
longer answer is we are looking into this. the specific auth route you are seeing is Grasshopper trying to sign in with Desktop Services which is no longer bundled (shouldn’t be necessary)
@ashdotio please check the Rhino connector and point to the app.speckle.systems and login from there. Then try to use GH nodes again - you don’t need to login again from GH.
it is Speckle server I try to login in Rhino and report back.
This is now fixed and will be in the next connector release. Until then, sign in through the Rhino Speckle panel, and Grasshopper will pick up the account.
Thank you both.
