we recently deployed our own Speckle server on a Ubuntu server 22.04.3 using your documentation: Deploying a Server - manual setup.
Our deployment is using the integrated PostgreSQL and Redis installations, but AWS S3 instead of the included minio. We have added the TLS certificate from Let’s Encrypt and serve everything over HTTPS.
While most features seem to work (including sending/receiving Stream objects via Blender Connector), we noticed that we were unable to upload files directly in the frontend with the drag’n’drop feature. It always shows this error:
Upload failed with code 404 - no response
Checking the browser console log shows us that the API returns status 404 response for this request: https://[OUR_SPECKLE_SERVER_ADDRESS]/api/file/autodetect/491ac3f1fb/test and the /graphql WebSocket connection is not working:
Failed to load resource: the server responded with a status of 404 ()
WebSocket connection to 'wss://[OUR_SPECKLE_SERVER_ADDRESS]/graphql' failed
WebSocket connection to 'wss://[OUR_SPECKLE_SERVER_ADDRESS]/graphql' failed: WebSocket is closed before the connection is established.
Our docker-compose.yml looks like this:
version: '2.3'
services:
# Speckle Server dependencies
postgres:
image: 'postgres:14.5-alpine'
restart: always
environment:
POSTGRES_DB: speckle
POSTGRES_USER: speckle
POSTGRES_PASSWORD: speckle
volumes:
- postgres-data:/var/lib/postgresql/data/
healthcheck:
test: ["CMD-SHELL", "pg_isready -U speckle"]
interval: 5s
timeout: 5s
retries: 30
redis:
image: 'redis:7-alpine'
restart: always
volumes:
- redis-data:/data
ports:
- '127.0.0.1:6379:6379'
healthcheck:
test: [ "CMD", "redis-cli", "--raw", "incr", "ping" ]
interval: 5s
timeout: 5s
retries: 30
reverse-proxy:
image: traefik:v2.10
command:
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.websecure.address=:443"
- "--certificatesresolvers.myresolver.acme.tlschallenge=true"
- "--certificatesresolvers.myresolver.acme.email=[CONFIDENTIAL]"
- "--certificatesresolvers.myresolver.acme.storage=/letsencrypt/acme.json"
ports:
- "443:443"
- "8080:8080"
volumes:
- "./letsencrypt:/letsencrypt"
- "/var/run/docker.sock:/var/run/docker.sock:ro"
# Speckle Server
speckle-ingress:
image: speckle/speckle-docker-compose-ingress:2
restart: always
ports: []
environment:
FILE_SIZE_LIMIT_MB: '100'
NGINX_ENVSUBST_OUTPUT_DIR: '/etc/nginx'
labels:
- "traefik.enable=true"
- "traefik.http.routers.speckle-ingress.rule=Host(`[OUR_SPECKLE_SERVER_ADDRESS]`)"
- "traefik.http.routers.speckle-ingress.entrypoints=websecure"
- "traefik.http.routers.speckle-ingress.tls.certresolver=myresolver"
- "traefik.http.services.speckle-ingress.loadbalancer.server.port=8080"
speckle-frontend-2:
image: speckle/speckle-frontend-2:2
restart: always
environment:
NUXT_PUBLIC_SERVER_NAME: 'local'
NUXT_PUBLIC_API_ORIGIN: 'https://[OUR_SPECKLE_SERVER_ADDRESS]'
NUXT_PUBLIC_BACKEND_API_ORIGIN: 'http://speckle-server:3000'
speckle-server:
image: speckle/speckle-server:2
restart: always
healthcheck:
test: ["CMD", "node", "-e", "try { require('node:http').request({headers: {'Content-Type': 'application/json'}, port:3000, hostname:'127.0.0.1', path:'/graphql?query={serverInfo{version}}', method: 'GET', timeout: 2000 }, (res) => { body = ''; res.on('data', (chunk) => {body += chunk;}); res.on('end', () => {process.exit(res.statusCode != 200 || body.toLowerCase().includes('error'));}); }).end(); } catch { process.exit(1); }"]
interval: 10s
timeout: 3s
retries: 30
depends_on:
postgres:
condition: service_healthy
redis:
environment:
CANONICAL_URL: 'https://[OUR_SPECKLE_SERVER_ADDRESS]'
SPECKLE_AUTOMATE_URL: 'http://127.0.0.1:3030'
SESSION_SECRET: '[CONFIDENTIAL]'
STRATEGY_LOCAL: "true"
DEBUG: "speckle:*"
REDIS_URL: 'redis://redis'
S3_ENDPOINT: 'https://s3.eu-central-1.amazonaws.com'
S3_ACCESS_KEY: '[CONFIDENTIAL]'
S3_SECRET_KEY: '[CONFIDENTIAL]'
S3_BUCKET: '[CONFIDENTIAL]'
S3_CREATE_BUCKET: 'true'
FILE_SIZE_LIMIT_MB: 100
EMAIL: "true"
EMAIL_HOST: "email-smtp.eu-central-1.amazonaws.com"
EMAIL_FROM: "[CONFIDENTIAL]"
EMAIL_PORT: "2587"
EMAIL_USERNAME: "[CONFIDENTIAL]"
EMAIL_PASSWORD: "[CONFIDENTIAL]"
POSTGRES_URL: 'postgres'
POSTGRES_USER: 'speckle'
POSTGRES_PASSWORD: 'speckle'
POSTGRES_DB: 'speckle'
ENABLE_MP: 'false'
USE_FRONTEND_2: 'true'
FRONTEND_ORIGIN: '[OUR_SPECKLE_SERVER_ADDRESS]'
preview-service:
image: speckle/speckle-preview-service:2
restart: always
depends_on:
speckle-server:
mem_limit: '1000m'
memswap_limit: '1000m'
environment:
DEBUG: 'preview-service:*'
PG_CONNECTION_STRING: 'postgres://speckle:speckle@postgres/speckle'
webhook-service:
image: speckle/speckle-webhook-service:2
restart: always
depends_on:
speckle-server:
environment:
DEBUG: 'webhook-service:*'
WAIT_HOSTS: postgres:5432
fileimport-service:
image: speckle/speckle-fileimport-service:2
restart: always
depends_on:
speckle-server:
environment:
DEBUG: 'fileimport-service:*'
SPECKLE_SERVER_URL: 'http://speckle-server:3000'
networks:
default:
volumes:
postgres-data:
redis-data:
Now we would like to know:
- We don’t really need the drag’n’drop feature. Is this problem an indication for another, more severe problem or can we ignore it as long as we don’t want to use it?
- Can this be caused by the fact that we use AWS S3 instead of minio? We noticed the server isn’t using the S3 bucket. In fact, it’s not even using the AWS IAM account credentials we provided in the
docker-compose.ymlat all. What is the S3 object storage even used for?
Thanks for your help!
Best regards
Sven
