Sending Solids from Dynamo to Speckle Not Working
I have created a Dynamo script using Dynamo for Revit that creates some custom geometry for me. I want to bring that into Speckle, but can’t figure out how to send my geometry. Right now, it is a solid geometry, but I’ve tried converting it to multiple meshes, one polymesh, and none of them have any displayable geometry when I look at the stream in Speckle.
Am I doing something wrong here?
Could you share the stream with me?
Our mesh definition is not likely compatible with what you are feeding in, but it’s likely a python snippet could solve that
I think solids and poly surfaces are not supported by Speckle yet, but the default Dynamo mesh should in theory work. Can you show how you converted it to mesh?
Yes, let me send the stream over:
https://speckle.xyz/streams/b31ffb6e55/branches/dome_fins
I’ve tried three methods:
Just sending a solid after the Solid.ByUnion node
Taking that solid and converting it to Polysurface with PolySurface.BySolid
And finally, taking that Polysurface and exploding it into individual surfaces with PolySurface.Surfaces
I took a little time away yesterday and I see you have found one of the many threads about SpeckleMesh I’ve started/contributed to.
I’ll take a look asap.
