jonathon
(jonathon@stardotbmp.com)
2
Would you be able to share that model with me? That error shouldn’t report for that selection mode for sure.
jonathon
3
Hey @AlexP,
I have isolated the issue causing this - working on a hotfix right now.
AlexP
(Alex)
4
HI @jonathon,
I try new version 2.15.1
but the same problem
AlexP
(Alex)
5
jonathon
6
Thanks. I’ll see what’s up in my tomorrow
jonathon
7
@AlexP I have been unable to reproduce your issue with the file you provided.
I have used the selection method you showed originally Item
> Guid
> not equal to
> 0
I have also downgraded to 2.15.0 and could not replicate that either.
I have tested with both Manage 2022 and Manage 2024. Are you using Simulate?
Do you have other ADSK/Rhino Speckle plugins installed with different versions?
AlexP
(Alex)
8
@jonathon thank you I will try another PC
I have installed only Navis and Civil3D
I am using Manage 2022/
AlexP
(Alex)
9
Hi again,
I’ve install Navisworks 2024 version on clear System, but faced with the same problem.
The query is the same “Element GUID != 0”.
@jonathon could you help me please?
jonathon
10
Still the same file?
I tried lots of different factors and couldn’t replicate.
I will check again. There’s no reason I can think of that localised language should cause this but I’ll explore that.
AlexP
(Alex)
11
Hi @jonathon!
I solved it.
The problem was with the localization of Navisworks.
jonathon
12
That is an excellent discovery. I’ll dig into making things language neutral!
Internationalisation is a medium term mission for us, but that is for UI, it shouldn’t affect core functionality.
jonathon
13
I have added a fix that should come out in the next release.
