Hey everyone!
I would like to run the integration tests on a functioned cloned from the python automate template. I created the .env based on the example and i also created a function_inputs.json
on the root of the project.
I replaced my token, project id, model_id, and automation_id but I am not sure how to get the automation_run_id and function_run_id
With the current values I have I get this error:
self = <gql.client.SyncClientSession object at 0x7f4aaa32a540>, document = DocumentNode at 0:673
variable_values = {'automationId': '3f6392320e', 'projectId': '24fa0ed1c3'}, operation_name = None, serialize_variables = None, parse_result = None
get_execution_result = False, kwargs = {}
result = ExecutionResult(data=None, errors=[{'message': 'Automation not found', 'locations': [{'line': 4, 'column': 7}], 'path'...ATION_ERROR', 'exception': {'name': 'T
riggerAutomationError', 'message': 'Automation not found'}, 'statusCode': 500}}])
- This is the automate function: Log in - Speckle
I assume that3f6392320e
is the automationId right?
Thank you for your help
