Hej!
Running into an issue when trying to send out a modell with properties attached from archicad.
Objective: Sending Archicad geometry (cca 3500 objects) with all advanced settings enabled ( Send Properties, Listing Parameters)
Issue : Running into an error halfway through that reads "Request cancelled due to httpClient.Timeout 300seconds timeout ". First question: Is this 300s set on our server or does the limitation come from the connector?
I am able the full modell with 30000 elements if i dont send properties and Listing parameters, but i get a timeout on 10% of that if i enable those options. Is this expected behaviour or is it something with the modell that causes it?
