Now that Rhino is officially in Beta, is it possible to have connectors for Grasshopper 1? When I install it always finds my Rhino 7 version. There’s a lot of new features I would like to explore but all my apps use Speckle.
Hey Phil,
We’re looking at it internally and are aiming to sync up with its official release!
Hi Matteo, any updates on the release date of a Rhino 8 connector?
What is the status on the Rhino 8 release? Since Rhino 8 has brought a lot more data workflows, its a perfect fit for speckle.
Rhino 8 compatible release is due soon. In the meantime refer to the answer I pasted right above your question.
hI,
are there any news with rhino 8 compatibility ?
Thanks ! =)
For the time being, the solution posted above is still the only support for Rhino 8.
Thanks for your reply,
The problem is i don t get the option to load speckle
Do you know what may be causing this ?
(i have already setup runtime to framework)
Have you followed the Install button at the bottom of the list and then navigated to C:\Users\YOUR_USER\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)
I don’t recall if it then needs a restart, but this is definitely all it took for me to get it running.
Hey @PhilSouthwell @Raouf_Djema @bfortunato @hallowXLR ,
Good news. Rhino 8 connector is available (as early release). Give it a try:
