I am trying to create an easy-to-modify topography workflow. Modelling a mesh in Blender and then creating topography from that mesh in Revit is the goal. I’ve had this workflow working before using Dynamo when I just export an .obj file but when I use Speckle it creates a generic model and I’m not sure if Dynamo or Revit can read that as a mesh.
You can receive Blender mesh directly in Dynamo using Receive node. Than using the mesh vertices, you can use Topography.ByPoints to generate the topography.
If this doesn’t help, can you share the stream here or add me ([email protected]) as a collab so i can better investigate on my end.
I gave it a quick try with the below commit from Blender and it works as expected. You can use the attached Dynamo script and modify it according to your needs if you want to.
You can’t install any of our connectors if any of the softwares we support is open. So first you have to close your Revit session (and if open Rhino, Blender etc.), install the Dynamo connector, reopen Revit.
PS. Dynamo connector is installed from Speckle Manager. It is not installed from the Packages thing in Dynamo.
Sure I have been closing down revit and forcing end task on it as you added in a warning about it. I’m even resetting my PC to get it working. It’s still not in the package list unfortunately.
Hi @scottyvalentine maybe there’s another package conflicting with Speckle, you could try disabling the others temporarily. To do so, just open the packages folder and move everything else to another location…
Let us know if it works!
PS
Also let us know if you have anything under notifications:
