Revit Project Parameters created don't appear in Powerbi
Hello!
The Revit Project Parameters that I created don’t appear in Powerbi, only the original parameters. However they exist in the speckle online version of the element. Any idea for the lost of data in transfer?
Thank you.
Thanks for reporting @R_Machete and welcome to the Speckle community!
This is a common experience and we have a solution for you. If you have not already done so, you can follow the step by step listed here: Extracting Parameters from Revit Data in Power BI
I wonder from your PowerBI screenshot that you have done this already. Please do check the Method 2 described on that tutorial: Speckle.Revit.Parameters.ToNameValueRecord([params])
This will translate any parameters listed behind GUIDs and make them available via their property names.
Thank you for the reply.
I had already followed the video suggested before posting.
Regardless the problem resolved itself as I tried again.
