Revit plugin not working the graphql failed
Hi guys,
since yesterday the revit plugin is not working. it was working before.
What"s the solution ?
I need to make a presentation soon, so if i have too much problems, i ll unfortunately have to choose an another tool.
Did you change anything at all?
Connector version? Network/Firewalls?
I am seeing many errors returning “forbidden” as the root error.
Share your log file with us to confirm I’m looking at the same things causing your errors. You can find the logs here: %appdata%\Speckle\Logs\
A possible solution would be to remove you account with Manager and re-add it. but I don’t want to go there yet if we can pin another cause.
ok, i just have disconnected and reconnected and that’s working. thank you
