I’m trying to connect Revit inside Speckle - even when opening Speckle as Admin - it still gives me same message “use admin to open speckle”. How can I solve this? I did not face this issue while connection Rhino and GH in Speckle.
Hey @Unicorn, welcome to Speckle.
Can you give a bit more detail where you see this error? The revit connector should pick up the same account as Rhino from Speckle Manager.
If you can give screenshots of the Revit connector … or is this error while you are installing… ??
Hi - Im basically getting this message although I am running speckle as admin. So its not allowing me to innstall revit in connector.
Oh yay. What’s your computer setup looking like? Is it controlled by an IT department, is it by any chance a cloud desktop, etc.?
Is there by any chance any revit related process still dangling open? eg., when you search for autodesk/revit what do you see?
