Hi!
I try to these data to speckle from Excel for testing:
however when I receive it, the header sorts from A-Z for me automatically. How can I avoid this?
and, can I keep the format? (e.g. column size)
Hi!
This is a current functionality due to the way Speckle stores and serializes the data.
If column ordering is critical, it is a good practice to keep a separate presentation sheet from the raw data sheet.
I can also raise a feature request to explore the possibility of preserving column ordering and formatting during the data import/export process. If you could explain where the data is coming from, this might be tied to that.
