I’m trying to receive data from Revit and utilize the new beta ‘view changes’ option on the web app. I’m attempting to understand the origin of this data (see attached screenshot). The ID associated with it will change when I send the data, but I haven’t modified the object.
Is this ID generated by Speckle, or does it originate from Revit itself?
Interesting, thank you for this clarification. I just went through all the data of the object (old vs. new), and all the geometry and parameters are the same. I can’t find anything different other than the ID that Speckle generated. I must be missing something !
I just realized that my screenshot was highlighting two different objects. Here is a clearer screenshot comparing the old and new versions.
"I will continue to investigate or conduct more tests to find out why this ID changed. Thanks again.
