Question: I have checked the speckle system status and it looks ok however, the issue still exists. when i click get data in Power bi and search for speckle it shows get model URL by beta or structured but not stream, would you please advise
Thank you for seeking help! Our friendly community is here to assist you. :pray:
  • Speckle Status: Please check that our systems are up and running: https://status.speckle.systems/
  • Objective: What are you trying to achieve, e.g. Receive Blender data in Excel, Use REST to query comments, …
  • Issue: If you suspect a bug, describe what you expect to happen. Explain what is happening or failing to happen. If you instead need a guiding hand, where are you stuck?
  • Example: Help us reproduce the issue by attaching sample files, giving a step-by-step reproduction guide and screenshots/videos if available
  • Speckle link: What better way to share data than using Speckle?
  • Logs: If the issue regards our desktop connectors, please share the relevant logs you find under: %appdata%/Speckle/Logs
Can you please explain you issue more in detail?
Here are some PowerBi tutorials: Power BI - Speckle - The Platform For 3D Data
I have transferred my Revit Model to Power BI by using the Speckle connector; after transferring the model, I opened Power BI and clicked Get Data, and searched for Speckle connector. Then I clicked it, and a dialogue box opened to paste the link. The dialogue box opened was Model URL, not the stream URL I needed to stream my model, but the option for streaming did not appear. Could you please help me
Sorry @basil_alsultan that is on us following The Great Rename. Streams are projects, Branches or Models and Commits are Versions.
We’re still discovering everywhere that this needs to be updated, and some recorded tutorials are last on that list.
Our docs have the right wording, but many visual assets have not been updated to suit. That will, however, make the comparison of the terms I mentioned above clear: Using Power BI Connector | Speckle Docs
