Question: How can I get the sets information foram a Navisworks file
Hi everybody, I made a separation in a file via Navisworks manually because my model was poor in information and I have put it in sets. Is there a way to get these sets in Speckle? My goal is to select these sets in a filter in Power BI visualization.
There is currently no way to save the Set an object is within as object data.
You could upload each set to a separate model in a single project in Speckle and then make multiple queries in powerbi.
Does that sound like what you want?
“I understand what you’re saying. I will consider this option since there is no other way. Another option I thought of was changing some custom properties in Navisworks, but I didn’t find a way to do this with multiple objects. Thanks for your answer.”
