Hi lovely Speckle people! I’m a very enthusiastic Speckle user, but writing scripts etc is new for me - so I’m coming here to see if what I’m trying is even possible ^^. I’m currently trying to setup a workflow that uses .json data (generated via a tool) to replace values inside of a Revit Family. See below for more information:
Speckle Status: All good
Objective: Would like to send (.json) data from Python to Speckle and receive this inside Revit to update parameters inside of a Generic Annotations family. We “need” a place to store this data too, that’s why I was thinking of using Speckle!
Issue: With my good friend Co-Pilot, I’ve created a Python script where I push the .json data to my desired Speckle stream. Receiving this data into Grasshopper and deconstructing the Speckle objects, makes it look like its properly converting this data to (in my opinion) something usable.
Now when I try to receive this data from the stream into my Revit model, and try to update the Generic Annotations family, nothing happens sadly enough.
import json
from specklepy.api.credentials import get_default_account
from specklepy.objects import Base
# Step 1: Connect to Speckle
client = SpeckleClient(host="https://rhdhv.speckle.xyz")
account = get_default_account()
# Print account details for verification
print(f"Authenticated account: {account}")
client.authenticate_with_account(account)
# Step 2: Read the .json file
with open('*Filepath\\Downloads\\output.json*', 'r') as file:
data = json.load(file)
# Step 3: Create a new Speckle object
speckle_object = Base()
# Add the parameters to the Speckle object
parameters = []
for param in data["parameters"]:
param_obj = Base()
param_obj["name"] = param["name"]
param_obj["value"] = param["value"]
param_obj["units"] = param["units"]
parameters.append(param_obj)
speckle_object['parameters'] = parameters
# Add family and type information
speckle_object['family_name'] = data["family_name"]
speckle_object['type_name'] = data["type_name"]
# Verify the structure of the Speckle object
print(f"Speckle object data: {speckle_object}")
# Step 4: Send the object to Speckle and get the objectId
transport = ServerTransport(client=client, stream_id="22a48a24cc")
object_id = operations.send(base=speckle_object, transports=[transport])
# Step 5: Create a new commit in the stream
commit_id = client.commit.create(
stream_id="22a48a24cc",
object_id=object_id,
message="New version from script"
print(f"Object sent to stream 22a48a24cc, commit {commit_id}")
Heres an image of what the family looks like; I would like to update this table with the parameters found to the right. Am currently testing with the 8LOA and 8LOB values first - would like to update all parameters eventually.
Would love to hear the possibilities and if there is a possible solution to this! Thanks in advance, if any more information is needed, I can try and share it.
Thanks for the super clear post. Sounds like an interesting “problem” you’re dealing with. If I’m understanding everything correctly, the piece of the puzzle that is missing, is updating the generic annotations family with some of the .json custom data.
The first thing that came to my mind - how are you linking the generic annotation family in Revit with the data from the json file for the update to take place?
Updating the family with the generated .json data is indeed the missing piece of this puzzle!
If I understand your question correctly, I am trying to link the data in the same way as I would do in Grasshopper (perhaps this is where it’s going wrong), by providing the Family name, and type (found in the .json), which I think would look like something like this in Grasshopper:
In this case there is no geometry to send to Revit, only data, so I can’t use any of the SSO objects within GH.
So this is what I thought would do about the same thing as the grasshopper component:
speckle_object['category'] = "Generic Annotations" # Ensure the category is set to Generic Annotations
I hope that’s an answer to your question!
Something I just noticed, what could possibly help understanding the issue and find a solution better:
I’ve just changed a setting inside Speckle Revit, where I put “Missing Type Mapping” to “Always”. Trying to receive the data after changing the setting, shows that there is no Type coming in at the first place:
Okay, right. I think we’re getting to the bottom of this . Could you send the Revit model with revit families to the same project you linked (maybe under a new model) (it’s ok if there’s no geometry). I just want to inspect the families you’re targeting.
Instead of investing a lot of time into updating the .json structure, how about:
Receiving the information from speckle team test in Python using specklepy
Doing some changes to the desired values in Python
Sending whole (updated) commit back to the same model
Test receiving that updated commit back in Revit where the original family came from and see if the family updated.
Some help on receiving and deserializing a model can be found here. Note some of the parameters may be different depending on the specklepy version you are working with (but the flow required remains the same).
Let me know if that works! If so, we can then see how this fits into your workflow (bigger picture) and make it work in the original .json → Speckle → Revit approach.
The id is expected, this is a speckle thing and is generated when serializing . I assmue, that speckle team test model receives information from Revit, and updated parameters model receives updated paramter from the speckle team test model through a little python action?
Under this assumption, I have put the two models side by side and compared in dev mode. (Left being recieved from Revit, right being updated from python). The applicationId is the same which is good! This is from the hostApp (Revit in your case). The link between “old” and “new” should be established. However, you noted no updated. So, what could be happening
I notice, that the structure has changed a bit and the speckle_type for example changes. Could you change your python script around to purely mutate the received commit (maintain commit received from operations.receive and just change a few values). i.e. look to minimize instantiating and assigning of new variables, but just edit the original commit.
I’ve tried you suggestion, but haven’t had any luck with updating the family within Revit.
Just to clarify: I used the “Selection” id first and changed the parameter within this structure first.
Now, after changing up the script with your comment, I’ve used the “speckle team test” id, and managed to change only this “8LOA” value parameter. Now, the parameter within the “updated parameters” id is changed, still nothing happens in Revit sadly.
Only thing I notice, is that when sending back the data from python, the “units” are added and the totalChildrenCount goes from 0 to 4. - This also happens when I don’t change the parameters and just receive the data and immediatly send it back to the “updated parameters” stream…
Hi @Zacheyre_RHDHV, @bjoern is taking a deserved break right now - I’ll pick this up and see if I can track down with you why this hasn’t worked - bear with me as I get up to speed.
Hey @jonatohn! I hope @bjoern has a great time off and takes his well deserved rest! I’m really looking forward to tackle this together!
I’ll be taking a deserved break for a while as well, for the time being, my collegue @Naomi_Voerman_RHDHV will take over the rest of the communication for as long as needed!
Just to add some more information we’ve gained over the last week:
We’ve noticed that when we “receive” the data, there is a new object instance of the family placed inside the Revit project with the updated parameter (yay!), this object is just not visible, because its automatically placed in a hidden viewport we can’t access (error: “Cannot make an internal view active.”) - We think this might be something on Speckle’s side by placing an object in the first viewport found in the project.
We also this it would be nice to update a family by name and type, instead of object ID, so that we can update multiple types at once, what we have found is that it’s only updating the family where we have set a unique ID for, if the family is used in a different project, it might occur that the family ID is not the same anymore and then this workflow stops working. The name will always be the same, so this could perhaps be a more consistent way of updating the family or multiple families of the same type that could’ve been placed inside the project.
We’d love to hear from you guys! Perhaps we can schedule a meeting where we can show our findings?
Hey @jonathon. Reaching out on behalf of Zacheyre. Have you been able to notify @bjoern yet? We are really curious if it is possible to update a family/multiple families by the name in stead of an ID. We believe that could fix our issues!
Welcome to the Speckle Community Forum! Thanks for your patience and the prompt on this. We are now in full 2025 swing. Let me get the Christmas cobwebs out of my mind and I’ll get back to you ASAP!
Hope your days off were great! I’m getting back into the swing of things after my break as well. Have you had a chance to look into this yet? We’re very excited to make this work!
