Giving automation functions a go but getting this error when creating a release –
ERROR: failed to solve: failed to push automate.speckle.dev/***:v1.0.0: failed to authorize: failed to fetch oauth token: unable to decode token response: invalid character '<' looking for beginning of value
Tested on both a edited c# function as well as a clean c# template function – can access automation endpoints using graphql and with a token I’ve created but not sure how to check that the github secrets have been setup correctly?
My only hunch is that there might be a mismatch between the speckle account creating the new function/github account that gets authorized/linked.
Yeah its output from the build action log – further up in the log I can see that it succeeded logging into automate.speckle.dev (line 341/342) so potentially a parsing issue?
Sorry that you encountered this, it’s not what we want to deliver as an experience with Automate. We made some changes recently that appear to have caused this problem. I have now applied a fix to our systems which I hope will resolve the issue for you.
