Hello, I need help to solve this problem.
I have some projects that are loading for almost a day and have end.
How can I change this status or is there something that I can provide to fix?
Hi @Planejamento_Inusa ,
It would help us a lot if you could share these files with us, I just invited you to a Google Drive folder.
We’re rewriting from scratch the IFC uploader and will soon be fastrer and more stable.
I just share with you the files. Thanks.
Hello @teocomi ,
Is there solution for this question?
@Planejamento_Inusa, I’m checking this now. Your files were shared as Matteo jumped on a plane to New York.
Upload worked fine - I’ll check in a bit how import went.
Thanks @jonathon by the answer.
We in INUSA are so excited to see this resolution for our problem. It will be a start for a revolution here.
In the meantime, you can try other applications that import IFC files, such as Navisworks, SketchUp, Archicad, and more. You can then publish to Speckle from there.
