Project Base or Survay Base not working correctly when exporting from Revit
Hi all,
I’m having problems with the reference point when exporting from Revit to Speckle.
I have different buildings and different files and exported them individualy to Speckle. They are all correctly georeferenced (test them in a federated model in Revit and Trimble Connect). For speckle I tried with the project base reference and with the survay reference, and the buildings are in the same place inside speckle.
Anyone knows what is happening?
PS: I tried with the old revit plugin and with the Beta.
Hey @MiguelFrazao if you selected the the right options on export then it might be a bug in the connector.
Would you be able to send us a DM with the source models (dropbox, drive…) and some steps to reproduce the problem?
Hi @teocomi, after reinstall the plugin for Revit, the models started to export correctly to Speckle with the correct reference.
That’s great to hear it worked out @MiguelFrazao - please reach out anytime it happens again - it really shouldn’t, so keep us busy and informed.
