Hi There,
I just installed the Microstation connector on my machine but when I opened the software several times, the connector is not present in my panel? any idea? thanks
Hi There,
The connector is expected to work with CONNECT versions only. This is some we are seeking to address.
Hi Jonathon,
I managed to open it in connect edition, the issue now is cannot send my model to the website? see image below, thanks.
Please post the conversion log … it’s the right hand tab at the top of the connector ui
Hi Jonathon,
I think it is working now, I got a new question, how can I change the receive option to be just to be an update instead? thanks
my microstation model is keep on failing to send the model?
Hi guys,
I was not able to send the model from microstation? any help?
thank you very much
Apologies @joelO , while we try to be responsive as possible if you are posting outside of a broad European timespan of awakening, we might not give instant answers.
Earlier I asked when you first reported “zero items converted” I asked:
Any report you make to us, please help us to help you with as much context as possible.
Hi Jonathon,
Thank you very much for your response, please see image below if this is the conversion log that you are looking for?
cheers
A post was merged into an existing topic: Revit to Microstation
