I’m new on Speckle. I want to try the 3D viewer in PowerBI
I added my project in the Speckle Manger
But when I try to import it in PowerBi with the Speckle URL, I have this error
Can you help me?
Mirko
Can you help me?
Mirko
Hey @mirko.maccarronello
Does the solution suggested here solve your problem?
Hi @gokermu, now It’s running the import but I cannot see the 3D
Hey man,
Did you follow steps described here👇:
In short, after you select the 3D Viewer Visual, you have to connect Stream ID and Object ID inputs in order to see them in the viewer.
Thank you @gokermu for your support ![]()
Yes, as you can see on the right of the image I added Stream URL and Object ID.
I see that there is this message
Thank you
I tried also to filter to some element to reduce the number, but always the same error
Can you share the stream/commit you are trying to receive? I’d like to reproduce the issue you are experiencing. You can share it here or if its private, send me a DM.
@mirko.maccarronello as you shared in private, it is not an issue anymore.
hi! I have the same problem. what the solution is?
Hey @annakozacenko ,
Could you kindly tell me a bit more about the issue you’re facing? I’m here to help!
I have an issue “Too many values” as Mirko had earlier. My link:
https://speckle.xyz/streams/324e9274d0/branches/main
I have an issue “Too many values” in Power Bi visual. My link: https://app.speckle.systems/projects/548457419a/models/bd42735d87
