Hi @teocomi
I am looking for help connecting private stream data with PowerBI to create a dashboard.
Please suggest the needful
Ravi
Hi @teocomi
Ravi
HI @RaviDCPL
Our PowerBI data connector does support fetching data from private streams, but the 3D viewer is currently in alpha stage and for now is only available of displaying data from public streams.
As of right now, there is no way around this, but your suggestion is noted and we’ve already discussed some possible alternatives to enable this in the viewer side.
Thanks, @AlanRynne
I have another concern, regarding the data connection between viewer visual and other pia charts visual.
I am following available blogs but it is not getting connected.
Please help me to solve this issue
Thanks in advance
Could you send us a sample report and a gif highlighting this? You can do so privately if you’re not comfortable sharing any resources
Shall I get an update?
Not sure what could be going on here.
Could you share with us the stream and the report you are using?
Hi @AlanRynne
Please find the required details.
Attach Power BI report
Test PowerBI and Revit Connection.pbix (1.6 MB)
Stream Link - Stream | Speckle
Looking forward to hear from you soon
Best
Ravi
Well, It seems to load in my end using your report and version alpha5
of the visual.
No private stream warning.
Could this be an issue with your configured firewall on your machine or your PowerBI installation?
There is though, a bug in the loading logic that we’re already tracking and will be fixed in the coming weeks. Some objects will fail to load in PowerBI when sent from Revit Connector 2.13 and above
Hi @AlanRynne
I checked the firewall configuration; it is stopped on my machine, and the SOPHO endpoint is active on my device.
HI @AlanRynne ,
Is Private stream available with the last update of the connector?
I saw that I could load the data in of a private stream, not sure if this was already available the update prior.
Private streams have the same support as before:
We’re going to look into some alternatives to enable private streams in the following release.
Are there any updates on support for private streams for the 3D Visual?
@JWN1 nothing specific to report here other than it is very high on our agenda
Hi @jonathon ,
We would love to use the speckle connector for an upcomming project but we need to able to use the private stream. Is there already a timeframe insight?
Thanks for the prompt, @Erik_Beeren; the timeframe is as soon as possible. I know this is a non-answer, but with the development in all areas made by a small team, this is the best I can offer.
A link-shared project is not 100% private or publicly discoverable. The security you are afforded is that the project and model are protected by the entropy of the 10-character hex string, making it extremely difficult to guess without the direct link. In fact, with two 10-character hexadecimal IDs (one for the project and one for the model), there are about 2^80 possible combinations—essentially making random guessing impractical.
So, the data is as secure as who you share the editable workbook with.
