I am unable to launch the GSA from the Speckle GSA.
There is no response to either button press.
The version of software have installed
GSA10.0
GSA8.7
GSA9.0
Speckle GSA 0.11.1.0
thanks for any help
GSA10.0
GSA8.7
GSA9.0
thanks for any help
Hi @haru, and welcome to the forum!
From the announcement I seem to understand you need to have GSA 10.1 installed as it’s not compatible with 10.0. See below and let us know if that solves it!
P.S.
Maybe the connector could show an error message if the right version of GSA is not detected, up to you @daviddekoning if worth opening an issue ![]()
Hi @haru, thanks for flagging this! As @teocomi mentioned, SpeckleGSA 0.11.1 (11.1) works with GSA 10.1. Let me know if it still doesn’t work.
If you want to stick with GSA 10.0, please install the previous version of SpeckleGSA.
Hi @teocomi, thank you for your reply!
I missed that announcement. I didn’t check it enough.
Thanks to you, I was able to fix the problem.
I’ll try to update the GSA.
Hi @daviddekoning, thank you for the support.
I’ll try to update the GSA. I’ll let you know if there are any issues.
Hi I cant seem to receive my Revit File into GSA after pressing receive?
Using Revit 2022 - Speckle - 2.9.11
GSA 10.1 - Speckle GSAV2 - 1.0.0.0
Might there already be an issue I am unaware of or wrong or updated installer?
Speckle GSA is a community contribution by Arup, so let me ping @JdB on this!
