gjordanp
(Gabriel Jordán )
6 November 2024 20:19
1
Hi Speckle Team,
I have been having this problem for a while now.
Some Revit parameters are not visible in powerBI stream.
For example “Ciclo” Parameter from this model: 20067-lyon almagro - Lyon Almagro | Speckle
Is not visible in PowerBI Database.
The strangest thing is that it that the parameter exists in the viewer.
Some aditional info:
“Ciclo” revit parameter is a SharedParamater
I’m using PowerBi conector v20.2.0
This has been happening from beta versions at least for us.
This is the PowerBI File
SPKL_Missing_CBCID.pbix (301.6 KB)
Best Regards
jonathon
(Jonathon)
7 November 2024 15:38
2
Revit by default stores the values of Shared Parameters under a GUID which handles multiple paramteres having the same name.
The viewer automaticaly resolves the Guid to the display name.
We have added a function that you can use in PowerBI to do the same:
Speckle.Revit.Parameters.ToNameValueRecord
It is descibed in the docs and tutorials: Extracting Parameters from Revit Data in Power BI
I have the minimal example using your data here:
SPKL_Missing_CBCID.pbix (150.3 KB)
gjordanp
(Gabriel Jordán )
7 November 2024 16:17
3
Thank you so much! I haven’t looked at the tutorials since the Alpha version.
Best regards!
