Hi, I’ve combined models in PowerBi following the tutorial. I’m trying to have a slicer to be able to show one model or the other. It works fine the first two times I use the slicer… but then it doesn’t filter anymore and doesn’t reload: both models are shown and grayed out.
Below a test model and attached the pbi file. Am I doing something wrong?
It’s great to see you again! Thanks so much for reporting this issue. I was able to reproduce it, and we’ll definitely look into it. I’ll make sure to keep you in the loop as we investigate further. Thanks again for your help!
