Hi everyone! I’ve encountered an issue where loaded models in Power BI are no longer clickable. I can rotate the model and change views, but I can’t select individual elements for filtering with the cursor. I’m using Power BI Desktop version 2.132.1053.0 from 08/21/2024, with connector version 2.20.0. Has anyone else faced this problem?
I’m having this issue to in 2.20
We were looking into this issue on the weekend as experienced with some workshop attendees. There we saw it affecting not the version of power bi connector but where the data came from.
If you could both (@Kirill @wilham_MM ) confirm source applications for visible but not clickable data, please add that to your reports because it would be good to narrow down any potential fix.
Thanks @jonathon. I was just testing with data that came from Grasshopper.
I am filtering to “base” elements so that I can get out their parameters.
Interesting, for the hackathon we were using grasshopper to make unreactive elements reactive. If you could share minimal examples with us in a speckle project, that would be helpful. We could then either fix or advise best practices.
@jonathon can you view this model?
https://mottmac.speckle.xyz/projects/8ddd28e245/models/297736b3b8
Here’s the model I’m uploading. It was exported from Revit 2025. main - KG3 | Speckle
I also uploaded older models using the new connector. The result was the same.
Thanks both - ill investigate and report back
