Plugin installation error on qgis
Hello everyone, I hope you can support me by giving me a solution on the following error: while installing Speckle plugin version 2.10.1 on QGis program version 3.34.6 I encountered the following problem. I report the text below.
ModuleNotFoundError: No module named 'panda3d'
  File "C:\PROGRA~1/QGIS33~1.6/apps/qgis-ltr/./python\qgis\utils.py", line 423, in _startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "C:\Users/Utente/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\speckle-qgis\__init__.py", line 52, in classFactory
    from speckle_qgis import SpeckleQGIS
  File "C:\PROGRA~1/QGIS33~1.6/apps/qgis-ltr/./python\qgis\utils.py", line 892, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "C:\Users\Utente\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis\speckle_qgis.py", line 36, in
    from plugin_utils.object_utils import callback, traverseObject
  File "C:\Users\Utente\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis\plugin_utils\object_utils.py", line 5, in
    from speckle.converter.layers.Layer import VectorLayer, RasterLayer, Layer
  File "C:\Users\Utente\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis\speckle\converter\layers\__init__.py", line 19, in
    from speckle.converter.geometry.point import pointToNative
  File "C:\Users\Utente\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis\speckle\converter\geometry\__init__.py", line 12, in
    from speckle.converter.geometry.polygon import *
  File "C:\Users\Utente\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis\speckle\converter\geometry\polygon.py", line 25, in
    from panda3d.core import Triangulator
Versione Python: 3.12.3 (main, Apr 14 2024, 17:21:43) [MSC v.1938 64 bit (AMD64)]
Versione di QGIS: 3.34.6-Prizren Prizren, 623828f5```
Hi @Chiara01A3SProgetti ! Thanks for reporting this. Was it a typo, did you mean Speckle connector 2.18.1?
Unfortunately, the seemingly “minor” version bump in QGIS had a jump from Python 3.9 to Python 3.12, and Speckle is using some version of the libraries from the former. I would suggest to install QGIS 3.34.3 in order to be able to use Speckle before we make a new release. Hope this helps!
Thanks for the prompt response, I solved it by following the advice, super!
2 posts were split to a new topic: How can I download older versions of the QGIS connector
Oh wauw, thanks for highlighting this.
Python v3.9 → v3.12 is good, but that does indeed seem like a not so very minor change…
To add to the mess, it seems like on macOS, they have not updated Python beyond 3.9:
This means installing the plugin through qGIS’s Plugin Manager fails with the following error:
Couldn't load plugin 'speckle-qgis' due to an error when calling its classFactory() method
ImportError: C extension: None not built. If you want to import pandas from the source directory, you may need to run 'python setup.py build_ext' to build the C extensions first.
  File "/Users/daniel/.config/Speckle/connector_installations/QGIS/pandas/__init__.py", line 26, in
    from pandas.compat import (
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 923, in _import
  File "/Users/daniel/.config/Speckle/connector_installations/QGIS/pandas/compat/__init__.py", line 26, in
    from pandas.compat.numpy import is_numpy_dev
  File "/Users/daniel/.config/Speckle/connector_installations/QGIS/pandas/compat/numpy/__init__.py", line 21, in
    raise ImportError(
ImportError: this version of pandas is incompatible with numpy your numpy version is 1.20.1.
Please upgrade numpy to >= 1.22.4 to use this pandas version
The above exception was the direct cause of the following exception:
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 426, in _startPlugin
  File "/Users/daniel/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/speckle-qgis/__init__.py", line 32, in classFactory
  File "/Users/daniel/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/speckle-qgis/speckle_qgis.py", line 58, in
  File "/Users/daniel/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/speckle-qgis/plugin_utils/object_utils.py", line 7, in
    from speckle.converter.layers.layer_conversions import (
  File "/Users/daniel/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/speckle-qgis/speckle/converter/layers/layer_conversions.py", line 67, in
    from speckle.converter.geometry.point import (
  File "/Users/daniel/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/speckle-qgis/speckle/converter/geometry/point.py", line 12, in
    from speckle.converter.geometry.utils import (
  File "/Users/daniel/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/speckle-qgis/speckle/converter/geometry/utils.py", line 19, in
    import geopandas as gpd
  File "/Users/daniel/.config/Speckle/connector_installations/QGIS/geopandas/__init__.py", line 1, in
    from geopandas._config import options  # noqa
  File "/Users/daniel/.config/Speckle/connector_installations/QGIS/geopandas/_config.py", line 109, in
    default_value=_default_use_pygeos(),
  File "/Users/daniel/.config/Speckle/connector_installations/QGIS/geopandas/_config.py", line 95, in _default_use_pygeos
    import geopandas._compat as compat
  File "/Users/daniel/.config/Speckle/connector_installations/QGIS/geopandas/_compat.py", line 8, in
    import pandas as pd
  File "/Users/daniel/.config/Speckle/connector_installations/QGIS/pandas/__init__.py", line 31, in
    raise ImportError(
Python version: 3.9.5 (default, Sep 10 2021, 16:18:19) [Clang 12.0.5 (clang-1205.0.22.11)]
QGIS version: 3.36.3-Maidenhead Maidenhead, 2df9655469b
Python Path:
/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/lib-dynload
/Applications/QGIS.app/Contents/MacOS/lib/python39.zip
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/Pillow-7.2.0-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/geopandas-0.8.1-py3.9.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/netCDF4-1.5.4-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/statsmodels-0.11.1-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/opencv_contrib_python-4.3.0.36-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/pandas-1.3.3-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/numpy-1.20.1-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/Rtree-0.9.7-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/GDAL-3.3.2-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/pyproj-3.2.0-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/patsy-0.5.1-py3.9.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/Fiona-1.8.13.post1-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/scipy-1.5.1-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/matplotlib-3.3.0-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/rasterio-1.1.5-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/cftime-1.2.1-py3.9-macosx-10.13.0-x86_64.egg
/Applications/QGIS.app/Contents/MacOS/lib/python3.9/site-packages/numba-0.50.1-py3.9-macosx-10.13.0-x86_64.egg
Indeed, QGIS cannot be trusted with semantic versioning :smile: We are thinking of a new strategy, and possibly it will be to limit support of the new Speckle releases to specific current QGIS LTR versions (separately for Windows and Mac), not older not newer. Ambiguity even between minor versions is clearly setting potentially false expectations.
