Dear Specklers,
in the past, we took a look at the send/receive of Tekla to Revit regarding performance and time.
Tekla Trusses to Revit - some trusses don’t want to go through the ether - Help - Speckle Community
One of my colleagues now took a look at Speckle regarding Rhino/GH/Revit and benchmarked it against Konstru from TT. It is a big roof with 17000 steel members for a car production plant, but geometry wise nothing out of the ordinary. My colleague used the latest set of connectors and we used our own deployment.
Revit > Speckle - 7 mins
Speckle (Revit) > Revit - 18 mins
Speckle (Revit) > Rhino - 11 mins
Speckle (GH) > Revit - 2 hours
Speckle (GH) Send = - 1 min
Revit > Konstru - 15 min
Konstru > Revit - 20 min
GH > Konstru - crashes
In general not so much difference between both platforms, which is actually quite nice … we will probably never reach the performance of Rhino.Inside but if the duration is acceptable for the user, this should not be the problem. Interesting is the duration for the GH Receive into Revit, which took 2h … especially as the receive Revit to Revit took 18mins.
Would be cool if you could take a closer look at the GH to Revit send-receive in the upcoming release(s). We can also provide you with examples, in case you need something from us. Hope this feedback helps you in further improving the connectors.
Thanks in advance! Best,
Alex
