Hi everyone,
I installed the ORD connector, in the speckle ribbon is missing.
I’m using ORD CE - 2021 release 2 update 10 version 10.10.21.04
Does someone here uses the ORD connector with a recent version of ORD?
alternatively, is someone from ARUP here, and can tell me if the firm still uses their developed plugin?
I have succeeded loading the ORD speckle connector by copying the config file Speckle2OpenRoads.cfg after the installation, from
C:\ProgramData\Bentley\OpenRoads Designer CE 10.10\Configuration\Organization
to
C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\config\appl
beware, that currently the connector does not stream corridors geometry as solid objects, just hollow meshes. which is not sufficient for my need.
Excellent, thank you for pursuing the issue. By solid objects, where are you consuming the OpenRoads data?
Hollow mesh is definitely the fallback display mode for all Speckle geometry, but I’m unfamiliar with OR, how it authors geometry or how the Connector translates that.
