Hi! im running in to an issue after publishing a model to speckle.
the instances that have problems are related to the a mass instance (loaded fam).
In revit they have this location:
In speckle they show like this
any ideas what could be the issue ?
regards
Ricardo
alex
(Alex)
June 23, 2023, 12:38pm
2
Hi @Ricardo_Zepeda
Could you possibly provide an example stream where this issue is happening so we can properly investigate?
Cheers
sure here is the link Speckle
i can share the family too if needed
Jedd
(Jedd Morgan)
June 23, 2023, 2:14pm
4
Thanks @Ricardo_Zepeda
If you could share with us the Revit project I can give it a test.
Sure here is the project
revit model
anything else that may help let me know
regards
Ricardo
clrkng
(Claire Kuang)
June 26, 2023, 10:05am
7
Hi @Ricardo_Zepeda ! @connor and I just fixed some Revit instance bugs for the upcoming 2.15 release, and it looks like this misplaced element will be fixed with those changes. I did a quick test with the file you provided:
In revit:
In the speckle viewer:
I feel we have a rather similar problem :Revit models are separated
Thanks ! will try it out! can you share a light on why the problem happends ? i had it in previous projects too
yep seems like the same thing, let me know if the next release helps solve your issue
teocomi
(Matteo Cominetti)
July 4, 2023, 11:28am
11
That was probably due to some changes we did to the logic behind instances, you can read about it here: New in 2.14: Revit Element Instances
Since Revit’s API is not very consistent, we probably missed something
Hi, I get the same problem but with the 2.14.4 version.
Check these topic :
Export from Revit
Import in Tekla
