Hi all.
Could Transform be applied to the objects, say, Revit elements and change their positions in the models? Like wall[‘transform’] = transformObj …
Hi all.
Great suggestion.
I’m actually sketching out a tutorial around this.
There are reasons why that’s a good thing a possible thing and there are things where it’s untested whether it will break.
I was hoping to get it done before Christmas but the diary is stacked. Thanks for raising it. It will motivate me more to get it done quicker.
Thanks @jonathon for the answer
Well, it was rather a question
but yeah, it would be a cool feature for all the objects. As I got, for now you can apply transforms only for instance nested objects?
what im working on leverages the object class we have that is the same for instances. A Speckle Instance is an object that has a definition and a transform matrix
Therefore is super generic. What is also the case is that the transforms are always parent to child relative and not absolute.
So a Window is transformed relative the the wall, and in theory then we could have a generic container object that uses that wall - or even the entire Version Commit and then cumulatively move a project with a single object.
Yeah, in theory it could be a root Base object, or, at least a specific Collection object.
This sounds very powerful! Could that tie into what you mentioned here about geolocation / coordinate reference systems / base point: Speckle_Revit Export by Parameter Value_Mass Floors - #13 by jonathon ?
Programmatically and theoretically, this is correct, but this is what I’m exploring - essentially, what needs to be tested is the performance across receiving connectors:
In some instances (no pun intended), I anticipate SpeckleToNative to create new objects in a new location, and then the parent transform will not be present on resend but the transform has been “baked”.
In some other instances, the parent transform may be interpreted as a collection as any other and persist in republishing.
In others, this operation is not anticipated, in which case behaviour and outcome are unknown.
In essence, this is my exploration with a view to see what support we can offer for the use case reported by @Jonathan_Rabagliati : Moving ALL Geometry in an entire Speckle Stream/Project - #5 by Jonathan_Rabagliati
