Object creation in Speckle Format using Typescript
  1. You can publish geometry from Rhino using the SpeckleRhino connector, you can load this geometry into Revit using the SpeckleRevit connector
  1. Yes… I think that’s what you asked first - I linked the Example from Christian Kongsgaard, but there are other examples: [SpecklePy] Commiting Geometry to a Branch - #18 by bjoern
    Unless you mean that you can generate geometry in the Speckle web app. In which case, no.
