Hello everyone,
I am not able to make a data stream from Revit using Speckle
I tried the following
1- re installed the plug in
2- re installed the Speckle Manager
3- removed Dynamo connector
4- tried pre releases versions and older versions
5- re installed Revit
6- tried different Revit version
All the above could not solve the issue, please i need help
I’m looking into it now there’s a possibility some connection to our systems is blocked. Are you on a corporate IT network, behind firewall, using a VPN machine?
hey , just to let you know, i installed Revit and Speckle Manager on another device and used my accound and everything is working just fine, its not an account issue
what could be the issue ? that PC is my mian work station
ok, the only thing i can see in the logs is manager unable to retrieve some of the feeds it expects, this shouldn’t affect the Revit Connector.
Another roll of the dice - could you remove you speckle account and then re-add it. You’ll need to do this from manager on the machine that is failing as the Speckle Connector isn’t loading
also do you have another application we have a connector for to try other than revit - just to see if it launches not to test any send/receives
i guess i found the issue but i dont know how to solve it, this is what i get in my accounts for Speckle and no matter how many times i delete it keeps coming again, even when i uninstall the manager and install it again the same thing happen
@Thulfiqar, something on that main PC is blocking or mutating our API calls. We cannot diagnose what this might be; it could be anywhere between you and our website, a firewall, a router issue, something on the network or something installed on the machine.
Repairing a broken Revit installation can be a pain. I’ve done this several times. It doesn’t need to relate to speckle.
I your a only using Revit it can be done with a clean uninstall. How to Complete a Clean Uninstall of Revit products
A regular uninstall doesn’t remove a lot off things.
Other Autodesk products might be an issue as well. Like Desktop Connector, License Manager or some other addons.
