In Navisworks, you are able to select the specific elements / groups / collections that you want to send. I’d like to be able to select a group as an example, which contains sub-elements etc., and send it to Revit as a single geometry/element as opposed to the individual elements.
Is this currently possible? or would it be possible in the future as this would be extremely helpful.
Sorry for the late reply. This must’ve been slipped through the cracks. Unfortunately, converting grouped elements from Navis to Speckle as a single object is not supported. We will convert individual elements from Navis as individual elements in Speckle.
As @gokermu says, my apologies for this being missed.
Could you describe the sorts of sub-elements you mean?
I know there are a few occasions in Navisworks that individual geometry types are split - it varies a lot on the source formats and what Navisworks does with these.
It would be great to see a few use cases/screenshots that we might consider for this workflow. It could be that independently of Revit, this could be an improvement when we next look at the Navisworks roadmap. It is currently VERY granular with lots of objects.
Hie… I have the same problem with objects that are a group in Autocad Plant 3D. They come sometimes to Navis with all the elememts of the group separately and then travel to Speckle with all of these sub-elements.
Obviously the problem is not in the Speckle platform, but can be the solution…
Saludos
I’m actively developing Navisworks next-gen connector - and solving this point would be great to do if you have any sample models (can be treated very privately), as Plant is a widespread data type coming through Navis
Apologies for the extremely late reply!
Being able to ‘combine’ geometry, almost like a ‘solid by union’ feature or similar to what Inventor does when exporting a native Revit (Top assembly, top components or all parts) would simplify the elements being imported. This could assist with defining assets down the line
