Hello again,
A shorter and simpler question this time, is it possible to move a model from one project to another without pushing the model again? The models are all in Revit in case that affects how it would be done or if it is possible.
Hello again,
Currently, @HadiAram, this is 100% possible programmatically but not via the UI.
If you want to pursue the programmatic route, let me know; otherwise, I can move this support question to a feature request.
Hi @jonathon
For the UI, we could consider a feature request for it.
For programmatic route, I will check if it is still needed to move the models and come back with the answer.
