Model loads from Revit to Power BI only with one object
@wlipemoura We believe this now fixed. Thanks @dimitrie and @gergo
As a tip, if you have an existing query returning one row, make sure to “refresh preview” and this will refill the cache with lovely rows
@RSR_820920 @Vlasceanu_Dan Thank you also for your reports. This was not a PowerBI connector issue but a hiccup ont he server DB that only affected PowerBI and GraphQL queries.
I just did a refresh of my PowerBI dashboard and I can confirm that the problem is fixed. Thanks @jonathon !
Problem solved!
Thank you so much, Jonathon!
Amazing job! I had another meeting today and I could use speckle in there! So far, so right :wink:
Great @jonathon! It works perfect now.
Thank you for your fast response
