Model Checker function Issues
Hi, we are trying out the public function ‘Model Checker’ and having an issue with getting the function to run. The error log we are getting is this:
[prepare] 2025/04/02 15:18:10 Entrypoint initialization[c8f5484979-e4e81da91f-2e8a43] Reporting run status with content: {'projectId': '4b82917e9c', 'functionRunId': 'ead79f9bd092a6d', 'status': 'RUNNING', 'statusMessage': None, 'results': None, 'contextView': None}[c8f5484979-e4e81da91f-2e8a43] It took 0.76 seconds to receive  the speckle version 3992d2b69e[c8f5484979-e4e81da91f-2e8a43] e[92mDetected Speckle object schema version: 3e[0m[c8f5484979-e4e81da91f-2e8a43] Traceback (most recent call last):[c8f5484979-e4e81da91f-2e8a43]   File "/usr/local/lib/python3.11/site-packages/pandas/core/indexes/base.py", line 3805, in get_loc[c8f5484979-e4e81da91f-2e8a43]     return self._engine.get_loc(casted_key)[c8f5484979-e4e81da91f-2e8a43]            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^[c8f5484979-e4e81da91f-2e8a43]   File "index.pyx", line 167, in pandas._libs.index.IndexEngine.get_loc[c8f5484979-e4e81da91f-2e8a43]   File "index.pyx", line 196, in pandas._libs.index.IndexEngine.get_loc[c8f5484979-e4e81da91f-2e8a43]   File "pandas/_libs/hashtable_class_helper.pxi", line 7081, in pandas._libs.hashtable.PyObjectHashTable.get_item[c8f5484979-e4e81da91f-2e8a43]   File "pandas/_libs/hashtable_class_helper.pxi", line 7089, in pandas._libs.hashtable.PyObjectHashTable.get_item[c8f5484979-e4e81da91f-2e8a43] KeyError: 'Logic'[c8f5484979-e4e81da91f-2e8a43] [c8f5484979-e4e81da91f-2e8a43] The above exception was the direct cause of the following exception:[c8f5484979-e4e81da91f-2e8a43] [c8f5484979-e4e81da91f-2e8a43] Traceback (most recent call last):[c8f5484979-e4e81da91f-2e8a43]   File "/home/speckle/src/spreadsheet.py", line 161, in read_rules_from_spreadsheet[c8f5484979-e4e81da91f-2e8a43]     df = process_rule_numbers(df)[c8f5484979-e4e81da91f-2e8a43]          ^^^^^^^^^^^^^^^^^^^^^^^^[c8f5484979-e4e81da91f-2e8a43]   File "/home/speckle/src/spreadsheet.py", line 57, in process_rule_numbers[c8f5484979-e4e81da91f-2e8a43]     where_indices = df[df["Logic"].str.upper() == "WHERE"].index[c8f5484979-e4e81da91f-2e8a43]                        ~~^^^^^^^^^[c8f5484979-e4e81da91f-2e8a43]   File "/usr/local/lib/python3.11/site-packages/pandas/core/frame.py", line 4102, in __getitem__[c8f5484979-e4e81da91f-2e8a43]     indexer = self.columns.get_loc(key)[c8f5484979-e4e81da91f-2e8a43]               ^^^^^^^^^^^^^^^^^^^^^^^^^[c8f5484979-e4e81da91f-2e8a43]   File "/usr/local/lib/python3.11/site-packages/pandas/core/indexes/base.py", line 3812, in get_loc[c8f5484979-e4e81da91f-2e8a43]     raise KeyError(key) from err[c8f5484979-e4e81da91f-2e8a43] KeyError: 'Logic'[c8f5484979-e4e81da91f-2e8a43] e[92mFailed to read the TSV from the URL: 'Logic':'Logic'e[0m[c8f5484979-e4e81da91f-2e8a43] Automation run EXCEPTION after 1.35 seconds.[c8f5484979-e4e81da91f-2e8a43] Failed to process rules[c8f5484979-e4e81da91f-2e8a43] Reporting run status with content: {'projectId': '4b82917e9c', 'functionRunId': 'ead79f9bd092a6d', 'status': 'EXCEPTION', 'statusMessage': 'Failed to process rules', 'results': None, 'contextView': '/projects/4b82917e9c/models/e400efc912@3992d2b69e'}
My interpretation of this is that the function is struggling to read our tsv file that we have shared through a google drive link - is there a certain format this needs to be sent? We have just used the ‘copy link’ on google drive to produce a link.
It needs to be a published TSV that is web-shared. If you open that link, does it show up in the browser as a TSV raw text or does it take you to Google Drive.
Happy to test via DM if it helps
I´m having the same issue. If I put the URL for the TSV on the browser, it prompts for downloading it. What can I be doing wrong @jonathon ?
That in itself isnt necessarliy a problem - its just how your browser is setup to handle non html type content. The URL is a means to an end and should be pastable in the function configuration.
