Lost my beloved UI
I’m struggling with speckle web UI - I can’t select points and lines easily anymore, nor have access to included objects (treeview).
Is there a way to get it back?
I hope so, as it is really a pain now :frowning:
–Anne–
Could you provide any additional details, @Choochoote? That image is tiny, and I’m not sure what it shows.
Hi Jon,
Treeview seems to be gone (or I can’t find it). Since the UI update, selecting line and point geometries in Speckle has become really painful: point selection often fails, and sometimes it takes 30s just to grab a line/point. Before, it was smooth and efficient. Is there an alternative way now? I’d really like the old workflow back. :pleading_face:
Treeview and Models were consolidated to a single mode
Each Model’s hierarchy is available from the parent model.
To my knowledge, selecting points and lines hasn’t functionally changed at all.
It sounds odd that it takes 30s for you to grab a line/point. Do you mean that you click an object and it takes many seconds before the object is actually selected?
Before, as I had access to different object types from TreeView, selection was easiest.
Now, I dont have access to it anymore:
As my objects are a base objects holding bunch of lines, points and metadata.
I’m messing with selection - But as I never had to to it by hand before, it may have always been a pain!
Any idea how I could improve this?
