@RaviDCPL, under what environment? A cloud provider, local network, raspberryPi?
@RaviDCPL if you are just starting out in the whole cloud, self hosting space, we recommend using our Digital Ocean 1 click application, which we wrote a step by step tutorial about here. I suggest you try to follow that guide.
Hi @gjedlicska @jonathon @iainsproat
Following Digital Ocean 1 click tutorial guide to deploy server, and a YouTube webinar -https://youtu.be/jiEWIQYGvHE
Not able to add domain even it is added in Digital Ocean Networking
Please refer below image
Please help me to solve this issue
Thanks in advance
Ravi
Hi @RaviDCPL
This error occurs when the domain name is unable to be resolved to an IP address. This can occur if the domain name is new or recently changed, as the DNS A record (which links the domain name to an IP address) can take a few minutes to propagate to all DNS servers.
As enough time has passed, it should be available to use now; please try again and let us know if it now works for you.
Iain
Is it working if you leave it as using the IP address?
I’m able to replicate a similar issue locally:
Both MX Toolbox and AlienVault are reporting that a DNS record has not been created:
Additionally, running whois speckle-server-dgtra.com
returns No match for domain "SPECKLE-SERVER-DGTRA.COM"
Please ensure that you have followed DigitalOcean’s guide to adding a domain to their system: How to Add Domains :: DigitalOcean Documentation
Iain
If you are the owner of dgtra.com
then you can add speckle-server
to that as a subdomain and use that. But in the setup you have tried that would need to be a registered domain, yes.
Thank you for highlighting the problem when using a blank domain; I have fixed this in the latest version which is now available.
You may need to delete the droplet and start again to get the latest updates.
Iain
Hi Team
Not getting verification email after creating account in my private deployed server.
Also please help me to know how to access administrator right as I have created my first account.
Also,not able to find this section “Fill in information about your server under your profile page (in the lower left corner).”
Hi @RaviDCPL
With regards to the emails, did you provide the details of an email provider during the setup?
Once you have registered the first user, you can then sign in. At the top right hand corner you can click on your profile. You should then see the Server Management option.
Iain
Hi @iainsproat
I have not provided email during setup.
Yes I am able to find the server management
Regards
Ravi
To enable email you will need to input the details of an email provider during setup, as described in the guide: Deploying a Server - DigitalOcean Marketplace App | Speckle Docs
If you wish to edit the existing server configuration, instead of creating a new droplet and restarting the whole process, please read this forum discussion for pointers on how to do that: Configuring mailjet as email provider for Speckle server - #13 by iainsproat
Iain
Hi @jonathon
I have asked my colleagues to add a sub-domain “speckle.apps.dgtra.com” It is added before few hours and also added Name Server to DGTRA.COM hosting server , even I am getting below error
Please help me to solve this issues and refer below image
@RaviDCPL - to add to Jonathon’s comment, I would recommend using some of the diagnosis tools described in the above comment to verify if the domain has been configured correctly by your colleagues.
Iain
