RaviDCPL
(Ravi Shankar Kumar)
7 December 2023 07:49
1
Hi Team
Looking for help to deploy speckle server locally.
I went through the documentation, but I feel it is too old a document as now Speckle is much more mature and lots of features get added and updated.
Please share a few updated resources to complete the deployment.
Ravi
Hi @RaviDCPL
We try to continually keep the documentation up to date; there are guides for deploying Speckle Server with Docker Compose , Kubernetes , DigitalOcean 1-Click , and as a local development environment .
If you encounter any issues while following the guides, please ask for help in this forum and provide as much detail as you can.
Iain
RaviDCPL
11 December 2023 05:53
3
Hi @iainsproat
Shall I get more details resources to deploy speckle server from docker hub image?
And, how to create VM for deploying from Docker Compose?
jonathon
(Jonathon)
11 December 2023 09:17
4
@RaviDCPL , under what environment? A cloud provider, local network, raspberryPi?
RaviDCPL
11 December 2023 09:29
5
@jonathon I am looking for both Cloud Provider and Local Network
gergo
(Gergő Jedlicska)
11 December 2023 11:00
6
@RaviDCPL if you are just starting out in the whole cloud, self hosting space, we recommend using our Digital Ocean 1 click application, which we wrote a step by step tutorial about here . I suggest you try to follow that guide.
RaviDCPL
12 December 2023 07:43
7
Hi @gergo @jonathon @iainsproat
Following Digital Ocean 1 click tutorial guide to deploy server, and a YouTube webinar -https://youtu.be/jiEWIQYGvHE
Not able to add domain even it is added in Digital Ocean Networking
Please refer below image
Please help me to solve this issue
Thanks in advance
Ravi
Hi @RaviDCPL
This error occurs when the domain name is unable to be resolved to an IP address. This can occur if the domain name is new or recently changed, as the DNS A record (which links the domain name to an IP address) can take a few minutes to propagate to all DNS servers.
As enough time has passed, it should be available to use now; please try again and let us know if it now works for you.
Iain
RaviDCPL
12 December 2023 11:10
9
Hi @iainsproat
Tried again, but getting same error
Please help me to resolve
Thanks in advance
jonathon
(Jonathon)
12 December 2023 11:59
10
Is it working if you leave it as using the IP address?
iainsproat
(Iain Sproat)
12 December 2023 12:03
11
I’m able to replicate a similar issue locally:
Both MX Toolbox and AlienVault are reporting that a DNS record has not been created:
Additionally, running whois speckle-server-dgtra.com
returns No match for domain "SPECKLE-SERVER-DGTRA.COM"
Please ensure that you have followed DigitalOcean’s guide to adding a domain to their system: How to Add Domains :: DigitalOcean Documentation
Iain
RaviDCPL
12 December 2023 12:39
12
Hi @jonathon
Kept domain blank and not provide email address
Please see the error
RaviDCPL
12 December 2023 12:40
13
Hi @iainsproat
Yes, I am following the same.
Do I need to buy this domain from domain provider?
jonathon
(Jonathon)
12 December 2023 13:15
14
If you are the owner of dgtra.com
then you can add speckle-server
to that as a subdomain and use that. But in the setup you have tried that would need to be a registered domain, yes.
iainsproat
(Iain Sproat)
12 December 2023 14:50
15
@RaviDCPL
Thank you for highlighting the problem when using a blank domain; I have fixed this in the latest version which is now available.
You may need to delete the droplet and start again to get the latest updates.
Iain
RaviDCPL
13 December 2023 05:01
16
Hi @iainsproat
Thanks to the quick fix , I am able to deploy server with blank domain.
RaviDCPL
13 December 2023 05:07
17
Hi Team
Not getting verification email after creating account in my private deployed server.
Also please help me to know how to access administrator right as I have created my first account.
Also,not able to find this section “Fill in information about your server under your profile page (in the lower left corner).”
iainsproat
(Iain Sproat)
13 December 2023 10:13
18
Hi @RaviDCPL
With regards to the emails, did you provide the details of an email provider during the setup?
Once you have registered the first user, you can then sign in. At the top right hand corner you can click on your profile. You should then see the Server Management option.
Iain
RaviDCPL
13 December 2023 10:41
19
Hi @iainsproat
I have not provided email during setup.
Yes I am able to find the server management
Regards
Ravi
iainsproat
(Iain Sproat)
13 December 2023 10:50
20
To enable email you will need to input the details of an email provider during setup, as described in the guide: Deploying a Server - DigitalOcean Marketplace App | Speckle Docs
If you wish to edit the existing server configuration, instead of creating a new droplet and restarting the whole process, please read this forum discussion for pointers on how to do that: Configuring mailjet as email provider for Speckle server - #13 by iainsproat
Iain
