Loading Revit Family from Rhino are no longer in place from internal origin
HELP!
I’ve been using Speckle from Rhino to Revit for the past few months and it was perfect. But suddenly now the whenever i send from Rhino and Received in Revit, it is not in its exact location anymore.
It still works if I block it and send to Revit as a family, but if i received as separate meshes inside the Family, its far away, then i have move it manually without any snap points into place.
It started when I was using connector 2.20.3 for revit ,and now I’ve updated connector to 2.20.4, and it still happens.
Connector V3 still doesn’t support family environment.
Appreciate any advice. Thanks
From your report, this is not a problem with releases <= 2.20.2 ?
Were the load events preexisting saved cards that stopped working or are you describing a general pattern?
Thanks for your reply.
It wasn’t a problem even with 2.20.2, and I only updated manually to 2.20.3, and earlier it was working fine, but suddenly its not right. I updated to 2.2.0.4 to check, but it still persist.
A workaround I find is to block in Rhino and send to inside family in revit, but this is a hit and miss. Sometimes it falls into place, but when it doesn’t, its near the the original. But if I don’t block it, it will appear received far away from the model. Just that previously block couldn’t be imported into family, but now it works.
