Is there a way to “receive” models in revit from its shared coordinates?
I have been using QGIS to create models then apply offset to send to Rhino, then i link the rhino file back to revit by its internal origin.
However, is there a way i can just load the layers data sent from QGIS directly to Revit for its shared coordinates? assuming the project base point is already acquired coordinates from a geo-referenced file with the same projection ESPG number. it should be able to load the content sent from QGIS without any offset to be in the right place in Revit?
