Keynote value in filtering is not the full value of the original keynote
Hello there!
I’m facing an issue related to filtering elements by Keynote value in the app viewer.
Using parameters.KEYNOTE_PARAM.value in filtering is not returning the elements original Keynote value.
Using parameters.KEYNOTE_PARAM.value in filtering is not returning the original keynote value of the elements. From what I’ve gathered, for a structure like string1.string2.string3, it gives the string after the last dot, considering it as a separator, ignoring everything to the left.
This doesn’t happen if i use a Keynote value without dots, like string1_string2
Any idea on how to avoid this without having to change the entire Keynote system?
Thanks in advance.
This seems like something we must fix our assumptions on - you shouldn’t have to change how you work.
